Capture bind values - management zone setting
urs_fischer
Helper
Hy everybody,
We use Management Zones to separate Applications. Now one Application wants to see the bind values and other management zones are not allowed to do this (in the same Environment). Is there a possibility to configure this on the Management Zone level:
(https://www.dynatrace.com/support/help/how-to-use-dynatrace/databases/support-for-sql-bind-variables)
Have a good one 🙂
3 REPLIES 3
xu
Visitor
Did you get it resolved?
No, as far as i know at the moment it is not possible on management zone level, only on environment level.
xu
Visitor
Provides permission control option on management ,but it doesn't work. Is it a defect?
