Discrepancy between number of Problem ID on GUI vs JSON
Hope someone can clarify following discrepancy. Here is managed DT cluster and I am selecting one tenant one day timeframe, filter out and leave only Error type of events outside of maintenance window. GUI shows that there are 5 such events with ID 673, 285, 983, 67, 924
Then I downloaded data via API, imported at excel pivot table and I see that instead of 5 events, I have 13 Error type events which lists above listed events and 8 more.
I see the same situation on other days as well, actually for the whole week in JSON file there were 40 Problems, while GUI showed only 28.
Anyone can give some explanation?
7 REPLIES 7
ChadTurner
DynaMight Legend
DynaMight Legend
The Problem number so recycle - but the ID will always be unique. This can be found in the URL and in the API pull of the event
-Chad
I understand that the Problem is in the 1-999 range and it rotates. But I am asking about the different things - for the specific time range there are Problems and ID and the only subset of them are listed in GUI compared to JSON.
In the above-mentioned example problems with ID 15, 229, 504, and others I see in JSON but I don't see them when logged on at GUI. Why?
We changed that some month ago, based on community feedback. The problem short number no longer repeats and is not repeating anymore. Its incremental now and follows a well defined schema, starting with the first two numbers of the year like 21 followed by the month and followed with an incremental number. To easily distinguish them from security vulnerabilities, we prefix it with a P. So e.g. the first problem detected in Dec 2021 would become: P-21121
We changed that, the problem ID no longer recycles, its incremental now and does not repeat.
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
We do hide semantically duplicate problems from the UI. So once Davis found that two problems are semantically identical after some minutes (as problems evolve over time) Davis hides the duplicates from UI.
Nevertheless we do have to export them in the API as well as to send out close notifications, as alert notifications were also sent out already for duplicate problems. So receiving systems expect closing message also for duplicate problems.
Backlink is of course also working as expected, its just that the problem list does not show the duplicates.
Best greetings,
Wolfgang
Wolfgang, thanks.
I have follow-up questions then - how do I filter out duplicate problems from the JSON file? Is there additional tag/property/key with such problems/events helping to identify and filter them out afterward?
How a single point of truth can be determined/established? If the GUI is such a single point of truth, then I need to have data pulled via API and notifications to be in sync with it.
See - a problem is sent out via the notification system, support folks see n such notifications, then they log on to GUI and see n-m displayed on the page. Then the explanation and digging need to be done to determine which one is a real event.
How much time does it take for the AI engine to consolidate events/problems? Let's consider the following example - there is a setting that 'Failure Rate Increased' event will be sent out if it has been going on for 30 min or more. Will the notification sent out after 30 min include the duplicate events or only consolidated events will be sent out?
Yes you can. See the API specification as it exposes the linked problems information which informs about duplicate incidences that the AI has connected with any given problem.
Best greetings,
Wolfgang
