08 Nov 2022
05:41 PM
09 Nov 2022
09:48 AM
Before I open an RFI, i wanted to check with community.
Story is Dynatrace doesn't have a mechanism to shut-down over Alerting should a major event occur and our problems jump by 100's in under 1 minute. At the moment, our ITSM and email systems are flooded with 1,000's of Incidents and emails.
I searched metric explorer and found, dsfm:server.notifications.problem_notifications. BUT this only counts the number of problems that triggered a notification. I need to catch this event BEFORE the notifications start to go out.
Does anyone know if Dynatrace currently provides some metric that is a total count of Problems?
08 Nov 2022 05:59 PM
Seems that we have it for Security Problems, but not for "default" Problems.
08 Nov 2022 06:35 PM
Thanks Danne for confirming what I believed. I'll go open an RFI. Until then I'll just have to make a problems API call and capture the count. I'll then follow your lead from your Tips Video and use the Synthetics Javascript section to work more magic.
08 Nov 2022 07:09 PM
Hehe, you can even create your own metric, create an HTTP synthetic calling the Problem API to count the problems, and a following request to create a new metric with Post Custom Metric datapoint, then use this metric to create a Metric event... we can go crazy.
08 Nov 2022 09:09 PM
This is planned so you can upvote it:
https://community.dynatrace.com/t5/Dynatrace-product-ideas/RFE-we-need-metric-problem-in-metric-expl...
08 Nov 2022 10:14 PM
thank you. Upvoted!
(saved me an RFI write-up, thanks)
