Dynatrace Problem got closed because of no communication with the server that went into a hung state
preadi3
Visitor
Hi All,
  Has anyone come across a scenario where the problem opened and then due to the factor that server went into a hung state the problem closed.  The issue did not resolve however Dynatrace assumed that since there is no communication between the One Agent and server the problem can be closed.  Is this an expected scenario?
Kind Regards,
Prem
3 REPLIES 3
DanielS
Hi @preadi3 you mean that is closed instantly or maybe by the predefined times listed here ?
preadi3
Visitor
Problem was received in Dynatrace but since The Server went into a hung state, the problem auto closed in a 19-minute duration.  The support assumed that the problem is fixed because the problem closed.  Is this a normal behavior of Dynatrace?  Shouldn't Dynatrace receive another problem of host becoming unresponsive? Requesting Dynatrace support to throw some light into this issue.
for sure it is expected to have a problem of host becoming unresponsive.
