Dynatrace Problem got closed because of no communication with the server that went into a hung state
preadi3
Visitor
Hi All,
  Has anyone come across a scenario where the problem opened and then due to the factor that server went into a hung state the problem closed.  The issue did not resolve however Dynatrace assumed that since there is no communication between the One Agent and server the problem can be closed.  Is this an expected scenario?
Kind Regards,
Prem
3 REPLIES 3
DanielS
DynaMight Leader
DynaMight Leader
Hi @preadi3 you mean that is closed instantly or maybe by the predefined times listed here ?
The true delight is in the finding out rather than in the knowing.
preadi3
Visitor
Problem was received in Dynatrace but since The Server went into a hung state, the problem auto closed in a 19-minute duration.  The support assumed that the problem is fixed because the problem closed.  Is this a normal behavior of Dynatrace?  Shouldn't Dynatrace receive another problem of host becoming unresponsive? Requesting Dynatrace support to throw some light into this issue.
DanielS
DynaMight Leader
DynaMight Leader
for sure it is expected to have a problem of host becoming unresponsive.
