04 Feb 2025 05:09 AM
Application hosted on Kubernetes PaaS, what to know if Dynatrace can monitor it. if so any reference we can have document or in demo environment.
04 Feb 2025 05:29 AM
Hey @Sisapy09
Dynatrace supports a wide array of Kubernetes platforms and container deployment methods, if you can provide any more information about the Kubernetes environment such as which Kubernetes PaaS you are using then we can provide a more focused answer. If that's not possible at the moment then we have the following documentation pages detailing support for specific flavors of Kubernetes which will hopefully answer your question.
Supported distributions: https://docs.dynatrace.com/docs/ingest-from/setup-on-k8s/deployment/supported-technologies
Also there are multiple deployment options depending on the level of data capture required.
Deployment options: https://docs.dynatrace.com/docs/ingest-from/setup-on-k8s/deployment
