How to give startTime and endTime for events?
Naveen
Participant
I am using events API v2 (https://www.dynatrace.com/support/help/dynatrace-api/environment-api/events-v2/post-event) and trying to post an CUSTOM_DEPLOYMENT event but don't know how to give startTime and endTime as per documentation it should be integer value.
I have also tried passing current timestamp but it's giving an error.
5 REPLIES 5
Julius_Loman
DynaMight Legend
DynaMight Legend
Both parameters are in the epoch time format. You need to convert your timestamp into epoch format.
Keep in mind both parameters are optional. If you do not specify startTime, current time is used.
Hey @Julius_Loman is it in seconds or milliseconds?
In UTC milliseconds.
Hey @Julius_Loman I have tried below snippet, but getting error
Error:
The timestamps are too old in your case. You cannot push non-problem opening events older than 30 days.
