How to monitor Pod/Deployment stuff
heramb_sawant
Contributor
Hi Team,
Can Dynatrace help to monitor below  Pod/Deployment stuff. I am not able to find metrics to fulfill this requirement,
Pods/Deployment :-
Percentage of Unavailable Pods Out of Desired Replicas
CPU Requests/Limits vs Actual usage
Memory Requests/Limits vs Actual usage
Persistent Volume Utilization
Heramb Sawant
Here you will find all available built-in metrics for Kubernetes:
https://www.dynatrace.com/support/help/observe-and-explore/metrics/all-metrics#kubernetes
Have a nice day!
michiel_otten
Advisor
Hi there,
I think all metrics are within the platform. Persistent volume claims can be activated as a plugin.
Also it is possible to get information about all the requests and limits. I've even created an API script to get all the information of all the pods in a json file  combined with the average, maximum and 90percentile.
Just use the Kuberentrs overview page if you have configured Dynatrace to pull metrics out of the Kubernetes API.
