Ionic with Capacitor enable project
durgesh
Newcomer
I am looking for documentation to integrate dynatrace in ionic capacitor enabled app.
is it possible? can dynatrace support Ionic with capacitor?
Looking for your feedback as soon as possible.
Durgesh Patel
Community Team
Community Team
Hello @durgesh ,
Here is the list of all technologies supported by Dynatrace:
https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/
Capacitor isn't on it, but the Dynatrace Cordova Plugin has added support to Capacitor. You can check it here:
https://www.npmjs.com/package/@dynatrace/cordova-plugin#capacitor-instrumentation
https://www.dynatrace.com/support/help/how-to-use-dynatrace/real-user-monitoring/setup-and-configura...
If you have any questions about the Community, you can contact me at maciej.neumann@dynatrace.com
