Open Q&A
Minimum System Requirement for Dynatrace Kubernetes Operator?
agylpradipta
Helper
So when I tried to deploy OneAgent for AWS EKS, I got this error:
- cluster-name-activegate-0
Events:
Type Reason Age From Message
Normal NotTriggerScaleUp 98s (x121 over 21m) cluster-autoscaler pod didn't trigger scale-up: 2 max node group size reached
Warning FailedScheduling 69s (x42 over 21m) default-scheduler 0/3 nodes are available: 3 Insufficient cpu. preemption: 0/3 nodes are available: 3 No preemption victims found for incoming pod.
Is there any resource requirement for this Dynatrace to be able run in EKS?
Thank you in advance
3 REPLIES 3
BigBill
Frequent Guest
This may not exactly answer your question, but I installed AG and OA on AWS EKS using the operator and I didn't observe anything like that. Everything installed correctly and works properly.
Cheers,
BB
PacoPorro
Dynatrace Leader
Dynatrace Leader
Check the dynakube.yaml where you can find the  initial AG requirements
In addition: the kubernetes scheduler tries to schedule a pod on a kubernetes node based on the requested (not limit). So in the example above the nodes need to have 500m cpu available. You can reduce this number by decreasing this number. Of course you can't reduce this endlessly.
#Performance matter!
