Open Q&A
Monitor UDP Calls in PurePath with Dynatrace
mandritaca
Visitor
Hi. We have a component from where we make third-party calls over UDP protocol. Currently, it is not showing up on distributed traces:
So is it not possible to monitor UDP traffic from DT?
Thanks!
harald_berger
Dynatrace Champion
Dynatrace Champion
Hi, this seems to be a Java based PurePath. Please note that the OneAgent does only instrument certain Java APIs as documented (like HTTP clients etc). It does not instrument the protocol itself. So if the UDP communication is done e.g. with a socket, it will not appear in the PurePath.
