Open Q&A
Need help with Regex
I need help with regex for useractions. My requirement is to match multiple domains and when i test regex its working fine in regex tester but when i check in dynatrace its not allowing.
Here is my requirement to match below domains
www-pt.abc.com
asean-pt.abc.com
latino-pt.abc.com
But shouldn't match below domain
stg-manage.abc.com
Here is the regex i see working in regex tester ^(?:www|asean|latino)\-pt\.abc\.com
Please guide me with the right regex for my requirement in dyantrace.
Tarun
Julius_Loman
DynaMight Legend
DynaMight Legend
Where in Dynatrace are you trying to use the regex? Because in application detection rule you cannot use regular expressions to match the domains/URLs.
Babar_Qayyum
Hello @tarun_kumar_aga
You can use pt.abc.com to define which web requests for your applications.
For more insight:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/real-user-monitoring/setup-and-configura...
Babar
