Persistent volume claim monitoring/anomaly detection exclusion
Babar_Qayyum
Dear All,
To exclude a specific PVC from monitoring and disk space anomaly detection, what steps should be taken?
Babar
3 REPLIES 3
Hello @Babar_Qayyum
As a suggestion you can refer to the attached resources if it can be configured from K8s side and reflected in Dynatrace:
If we used the anomaly detection API:
curl 'https:///e//api/v2/settings/objects' \
-X POST \
-H 'Accept: application/json; charset=utf-8' \
-H 'Content-Type: application/json; charset=utf-8' \
-H 'Authorization: Api-Token ACCESS_TOKEN' \
-d $'[{"schemaId":"builtin:anomaly-detection.kubernetes.pvc","schemaVersion":"1.2","scope":"environment","value":{"lowDiskSpaceCritical":{"enabled":true},"lowDiskSpaceCriticalPercentage":{"enabled":true,"configuration":{"threshold":3,"samplePeriodInMinutes":3,"observationPeriodInMinutes":5}}}}]'
The section that would be changed the scope instead of environment DevOps can specify specific PVCs and exclude the others.
Or
  • Extract the Objects from the Environment API v2 and update the intended object via API and check if it's applied as expected or not.
Hopefully it adds value.
KR,
Peter.
Babar_Qayyum
Hello @Peter_Youssef
Thank you for your feedback. We can implement changes on the namespaces individually rather than at the cluster or global level; however, this approach would be quite labor-intensive. Consequently, I am looking for a more straightforward method to exclude items, similar to how we exclude disks.
Babar
Hello @Babar_Qayyum
Thanks for the updates, good to hear that.
Let's investigate the workaround 🚪😉😊.
