27 Jun 2019
03:52 PM
14 Dec 2021
01:20 PM
Is there an API or tool available to analyze problems logs over a period of time to determine trends? Dynatrace generates a large volume of problems, big and small, and have noticed that a good percentage reoccur over time. It would be of great benefit to have the ability to rank or watch certain problems having this knowledge since some are precursors the bigger problems down the road.
You can always use api to extract problems lists based on criteria of your choice. In such way you will be able calculate trends
