Problem Notifications - Slack Integration
Peter_Youssef
Leader
The attached configuration procedures describe the step-by-step integration configurations between Dynatrace and Slack for problem notifications.
About Slack
  • The AI-powered platform for work bringing all of your conversations, apps, and customers together in one place.
  • Helping businesses of all sizes grow and send productivity on the fly.
Prerequisites:
  • Communications should be allowed either between Dynatrace cluster nodes or ActiveGates and Slack endpoint URL.
Through Slack:
  • Slack team should follow the attached procedures to create the required Webhook.
  • Once created Slack team share it with Dynatrace team for integration configurations.
Through Dynatrace:
  • Specify the below mandatory configuration parameters.
  • Select the intended alerting profile and Send test notification.
:dynahistory:📯📢🚥:slack::dynatrace_logo:
0 REPLIES 0
