24 Feb 2023
11:17 AM
26 Feb 2023
11:58 PM
Hi Team,
Your support in knowing why it gives an error in the connection when performing a test from Dynatrace to Ansible.
Does it have to do with a firewall?
Regards
Hi Daniel,
Yes, it is with Ansible Tower.
Regards
Hi @MariaElena, if you're using Tower. Yes, could be a Firewall, or communication problems, can you check first if the Ansible Tower services are working ok?
