07 Dec 2023 02:02 PM
Dynatrace,
How long has it been since you introduced Settings 2.0? Seems to be at least 2 years based off this blog. https://www.dynatrace.com/news/blog/automate-dynatrace-configuration-management-at-scale-with-new-se...
When will all pages be moved to settings 2.0? We need to completely implement IAM Policies but not everything is complete in Dynatrace.
There are many pages that don’t seem to be on settings 1.0 or 2.0. How about these below? These pages don’t even have the I (information) to tell me what the schema id and group is. When will this be done?
| Settings | Web and mobile monitoring | Advanced setup |
| Settings | Web and mobile monitoring | Private Synthetic locations |
| Settings | Cloud and virtualization | Overview |
| Settings | Server-side service monitoring | Merged service monitoring |
| Settings | Server-side service monitoring | Global request naming rules |
| Settings | Log Monitoring | Configuration of log sources |
| Settings | Log Monitoring | Activate sensitive data masking |
| Synthetic | HTTP Requests | HTTP Requests |
| Host | General | |
| Host | Detected Processes | |
| Services | Naming | |
| Databases | Naming | |
| AWS | n/a | n/a |
| Applications | Capturing | User Tag |
| Applications | Capturing | User Actions |
| Applications | Capturing | Session and user action properties |
| Applications | Capturing | Async web requests and SPAs |
| Applications | Capturing | Content capture |
| Applications | Capturing | Advanced settings |
| Applications | Capturing | Resource capture for Session Replay |
| Applications | Behavior Analytics | Conversion goals |
| Applications | Metrics | |
| Applications | Errors | JavaScript errors |
| Applications | Injection | InJection Automatic injection |
| Process Groups | General | |
| Process Groups | Log Monitoring |
13 Feb 2024 08:20 PM
I feel your pain, I use to pull Schemas after every cluster update and identify what was new and if we could use them to allow even more granular permissions.
13 Feb 2024 08:21 PM
Crazy!!!!
15 Feb 2024 08:03 AM
Hi!
Yes, there are a bunch of settings pages that are not on the settings 2.0 tech stack. The unfortunate news first: they won't all receive a 1:1 transition. More details on that are below.
This, however, is not a dealbreaker regarding the manageability via IAM. With the introduction of IAM roles (docs here, released with 1.252), you can manage access control completely in IAM so no need to mix and match with traditional permissions.
Regarding the mentioned pages, features that have improvements coming up and/or are already being replaced by new versions (notably Log v1/v2 and service monitoring) are not planned to be changed.
The recommendation for anything entity-based (i.e. applications, hosts, process groups) is to manage access via management zones which is also possible via IAM (see example). Some individual pages for applications are coming, but for internal reasons and not with the goal of having full coverage of everything that is there right now.
best,
Michael
