Terraform provider and (remote) module state
Dave_Huze
Observer
Hi.
I'm hoping that someone can help me out here.  Ideally, I'd like to raise a feature request to be able to have granular tfstate files, one per module, however I don't know if this would be possible.  In the meantime, there is an annoying naming issue with the terraform_json_dashboard, which I'll describe here.
The scenario using the following, and I have used the deprecated dynatrace_dashboard - https://registry.terraform.io/providers/dynatrace-oss/dynatrace/latest/docs/resources/dashboard in this example just to act as a comparison.
./terraform-provider-dynatrace -export -import-state -id -ref '*' dynatrace_dashboard dynatrace_json_dashboard
 results in a single state file, which is understandable...
What I am currently doing to get more granular state files is programmatically creating a backend.tf for each module, as well as moving the necessary state to each module using:
d=target_dir; for i in $d/modules/*;do m="$(basename $i)"; t="module.$m"; tf state mv -state=$d/terraform.tfstate -state-out=$i/$m.tfstate $t $t;done
which works fine for every module other than terraform_json_dashboard:
Move "module.activegate_updates" to "module.activegate_updates"
Successfully moved 1 object(s).
Move "module.alerting" to "module.alerting"
Move "module.api_detection" to "module.api_detection"
Move "module.application_detection_rule" to "module.application_detection_rule"
<snip>
Move "module.dashboard" to "module.dashboard"
<snip>
│ Error: Invalid source address
│ Cannot move module.json_dashboard: does not match anything in the current state.
I can work around this exception but would rather not have to.  Does anyone know if there are any plans to natively provide the ability to save the state files per module, also if the mismatch of the dynatrace_json_dashboard module is intentional, or a bug?
Cheers,
Dave.
0 REPLIES 0
