Open Q&A
Webrequest cleanrule does not work
henk_stobbe
Leader
Good morning,
I am trying below cleanup rule:
(also tried %20 without ()), but that also did not work.
Is is a bug or is it a feature?
KR Henk
5 REPLIES 5
Julius_Loman
DynaMight Legend
DynaMight Legend
Maybe escaping the % with a \ ?
henk_stobbe
Leader
Hi Julius,
Thanks for the hint, sorry no luck....
Also tried " " \u0020 , (%)20  (-;
KR Henk
joseandrescalvo
Participant
Hi. Tested %20 as regular expression for clean up and it works.
Anycase, there is no need to include a capture group in regular expresions for cleanup rules: all matching strings are removed.
henk_stobbe
Leader
Hello Jose,
Thanks for your reply, need to investigate at my end. This does not work for my envoronment )-;
KR Henk
henk_stobbe
Leader
A second look: the %20 is part of a placeholder (URL query),
I created a naming rule adding a "query parameter". After adding the cleanup rule of %20, you can clearly see that this has no impact on the placeholder
So the solution is simple ,
You create two placeholders one that stops at the %20 and one that starts at %20 (so you split up with the help of the %20)
Have a great weekend!
