Hi @jyotisingh123
feel free to review and follow the attached steps
You will find monitored servers where the postgre sql is running.
- Navigate to the intended servers and configure the highlighted parameters.
- Then configure the metric events as per requirements, select the metric and then proceed with the remaining configurations as shown below.
Then save. 😉😊
- If you need to create a dashboard based on the metric events, it's easily configurable as well through Data explorer > configure required tiles > pin to Dashboard.☕
BR,
Peter.
