10 May 2019 06:24 AM
how to read SNMP logs and create alerts metrics around it
12 Mar 2020 12:15 PM
@Siva P. As long as the Dynatrace Oneagent is on the host that has the log file, I don't see why you cant get the file. I have attached a link that will help guide you through the process of manually discovering log files.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/log-monitoring/configuration/add-log-fil...
