x-dynatrace header max length
Romanenkov_Al3x
DynaMight Champion
DynaMight Champion
Hello. Can anybody tell me - max length of x-dynatrace header. Customer setting up firewall rules, so they need max length all request headers to allow application work, otherwise requests are blocked.
Thanks.
Alex
DT_NGINX_FORCE_UNKNOWN_VERSION_INSTRUMENTATION=1
7 REPLIES 7
HannahM
Dynatrace Guru
Dynatrace Guru
I don't believe there is a size limit from a Dynatrace perspective. Typically, the HTTP header size limit is dependent on the server. (Apache, Nginx, IIS, Tomcat)
I need value from Dynatrace. Expected answer - for example 200 symbols.
Look like this:
FW4;-712055999;35;-1057699572;862004;0;1310537445;1367;c15c;2h01;3hc0f4c90c;4h0d2734;6h6765016c4c42ea4085044906606ef4e6;7hc487f83ef5f244e3
This header added by Dynatrace. Only Dynatrace can know it. The question is not about web server settings.
Alex
Unfortunately the header length is not fixed. Depending on the situation encoded binary info will be added to header.
Harry
Thanks for fast response.
Rene
Observer
@harald_berger
Hello Harald,
We use Dynatrace for mainframe Cobol under CICS and have used a TAG buffer length of 100 bytes for the stubs based on the examples in your documentation.
assets.dynatrace.com/global/doc/appmon/integrations-and-extensions/development-kits/agent-developmen...
Now it has turned out that the length can also be greater than 100 bytes and we are having problems processing it correctly.
We know that the length is not fixed. In our tests, with different applications, we see lengths of 74 bytes, 85 bytes, 142 bytes.
What length would you recommend so that we can most likely cover all possible cases in the future?
BR; Rene
harald_berger
Dynatrace Champion
Dynatrace Champion
Hi Rene,
170 characters should be sufficient, if no custom tags are propagated.
Harry
Patrick_H
Dynatrace Leader
Dynatrace Leader
The x-dynatrace header can contain different content as it is used for e.g. web RUM and mobile RUM - see https://docs.dynatrace.com/docs/shortlink/rum-firewall
For mobile RUM the header content can vary in length, but is just calculated it and a max size of 150 chars for the header value (excluding x-dynatrace: name) should be save.
I can't speak for web RUM here where this header is set on OneAgent - so you probably will need a solution using biggest possible value for all scenarios.
iOS help: https://www.dynatrace.com/support/help/shortlink/ios-hub
