Is it possible to extract Problems for each Management Zone with Dynatrace-API?
Problems extracted by Dynatrace-API does not include ManagementZone item.
I would like to extract Problem information by API for each ManagementZone, but is it possible to realize this?
Best Regards,
Masahiko Enda
pahofmann
DynaMight Leader
DynaMight Leader
Currently it is only possible to filter for tags, not a management Zones.
It's a valid use case though, so you should open an RFE in the Dynatrace Product Ideas forum.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
Thank you for your reply.
I'll try to filter for tags.
