Management zone automation using Dynatrace REST
rswarnka
Helper
Hi, can we achieve automation of management zones like creation, updation using REST APIs?
3 REPLIES 3
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Yes you can create and update management zones through config API.
Best greetings,
Wolfgang
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
details: https://www.dynatrace.com/support/help/extend-dynatrace/dynatrace-api/configuration-api/management-z...
Senior Technical Product Manager,
Dynatrace Managed expert
jose-antonio_ra
Inactive
Hi Rajesh.
from Dynatrace API explorer, there are these options:
BR.
jose A
