Problem with Dynatrace Terraform provider
nadaKH
Newcomer
I'm trying to get Dynatrace environment configuration with terraform provider binary using this command:
terraform-provider-dynatrace_v1.0.5.exe download https://<env-id>.live.dynatrace.com <api-token>
but getting this error:
"code": 403,
"message": "Token is missing required scope. Use one of: ReadConfig (Read configuration), Davis (Dynatrace module integration - Davis)",
"constraintViolations": null
I already enabled the "Read configuration" scope for my API token.
Can someone help me plz? what am I missing?
0 REPLIES 0
