11 Oct 2023 08:44 AM - last edited on 13 Dec 2023 10:55 AM by Ana_Kuzmenchuk
We have found an issue when using kuberneres+OneAgent+RUM injection with some applications. Support helped us to eliminate possible causes and to narrow in on caching at the AFD level.
When caching is enabled, RUM injection does not work. If we disable caching on AFD, RUM Injection works every time.
To circumvent this issue, we've resorted to manual JavaScript injection.
Has anyone come across an alternative solution for this challenge?
13 Dec 2023 11:05 AM - edited 13 Dec 2023 11:05 AM
Hi @GregOReilly, were you able to find an alternative solution for this issue? Thank you!
13 Dec 2023 11:13 AM
Hello Anna, manual injection was the only method that worked. Using Oneagent and automated injection of Javascript did not work with Cache enabled on Azure Front Door(s).
26 Sep 2024 03:45 PM - edited 26 Sep 2024 04:56 PM
