Start with Dynatrace
Dynatrace Managed - Remote access permission
Peter_Youssef
Leader
Having cluster admin privileges, gives you the ability to control access to Dynatrace managed platform to Dynatrace support team.
Available Options:
  • All: DT support team can access without asking for permission.
  • Read-only access to all: can access with a very limit privilege, doesn't require access request approval.
  • Approved: after approving access request, DT support will be able to access and validate against the raised concerns.
Prerequisites:
  • Constant communications to Mission control should be maintained.
  • Enable the configuration button as per the attached screenshot.
  • If this option is turned-off, Dynatrace won't be able to access the platform.
Are the Dynatrace Support Team members direct employees of Dynatrace?
@HuseynNajafli yes.
