Start with Dynatrace
Synthetic Monitoring - Capturing Performance Metrics for Page Loaded In Frames
Peter_Youssef
Leader
Pros:
  • Gives more synthetic performance insights through capturing the performance metrics for the page loaded in Frames.
  • Capturing Missing XHR actions for third-party iframes.
Configurable through:
  • Dynatrace synthetic settings UI.
Tip:
As a cluster admin or Dynatrace platform admin with the attached privileges you will be able to apply the required configurations.
You can access the synthetics either the current configured or to configure new synthetics through any of the available options
Or
Then
Once Activated
Finally😎😊
Hoping it adds value,
🎚📱:internet_explorer::dynaspin:
KR,
Peter
HannahM
Dynatrace Guru
Dynatrace Guru
I would, also, recommend adding disable-site-isolation-trials for any sites using frames.
Hi @HannahM
Thanks for your valuable input, My pleasure to prepare.
