Start with Dynatrace
Synthetic Monitoring - HTTP Monitor - Configuring Client Certificates.
Peter_Youssef
Leader
Pros:
  • Enables implementation team configuring Client certificates to conduct secure connection to the Synthetic HTTP Request or API.
  • For some scenarios, the connection to the API will be rejected unless there is a client certificate installed.
  • The client certificates are provided by App Owner.
It's configurable through:
  • The synthetic monitor settings page.
Tip:
As a cluster admin or Dynatrace platform admin with the attached privileges you will be able to apply the required configurations.
You can access the synthetics either the current configured or to configure new synthetics through any of the available options
Or
Below are the Steps to configure client Cert 🔆
Then 🗻
🔖🖥:dynaspin:
Hoping it adds value.
KR,
Peter.
0 REPLIES 0
