Synthetic Monitoring - HTTP Monitor - Configuring Pre and Post Execution Scripts.
Peter_Youssef
Leader
Pros:
  • Enables implementation team configuring the Pre and Post execution scripts related to the Synthetic HTTP Request or API.
  • Mainly these scripts are provided by App Owner.
It's configurable through:
  • The synthetic monitor settings page.
Tip:
As a cluster admin or Dynatrace platform admin with the attached privileges you will be able to configure the required configurations.
You can access the synthetics either the current configured or to configure new synthetics through any of the available options
Or
Defining Pre and Post Execution Script:
Pre - Execution Script
Post- Execution Script
Then 🗻
Hoping it adds value.
BR,
Peter.
3 REPLIES 3
HannahM
Dynatrace Guru
Dynatrace Guru
Thanks @Peter_Youssef , there's some handy snippets here also
Appreciate your support and recommendations @HannahM , actually you're Synthetic Expert I'm learning from your posts and responses.
All the best.
You're very welcome. I love these bite-size how-to's you've created. They're really easy to consume and will be super helpful for people starting out with Synthetic.
