Synthetic Monitoring - HTTP Monitor - Setting Authentication and Authorization.
Peter_Youssef
Leader
Pros:
  • Enables implementation team configuring the Authentication && Authorization scripts related to the Synthetic HTTP Request or API.
  • These parameters are provided by App Owner.
It's configurable through:
  • The synthetic monitor settings page.
Tip:
As a cluster admin or Dynatrace platform admin with the attached privileges you will be able to apply the required configurations.
You can access the synthetics either the current configured or to configure new synthetics through any of the available options
Or
Below are the compatible authentication && Authorizations standards 🔆
Then 🗻
🔖🖥:dynaspin:
Hoping it adds value.
KR,
Peter.
HannahM
Dynatrace Guru
Dynatrace Guru
You can find more information on authentication in HTTP monitors here
