21 Oct 2024 05:17 PM - edited 29 Oct 2024 12:44 PM
Pros:
It's configurable through:
As a cluster admin or Dynatrace platform admin with the attached privileges you will be able to configure the required configurations.
You can access the synthetics either the current configured or to configure new synthetics through any of the available options
Or
Then
Hoping it adds value.
KR,
Peter.
23 Oct 2024 01:36 PM
A great scenario for using this is when a page returns a 401 initially but then accepts the credentials set in the HTTP Authentication. In these cases, we need to ignore the 401 on the page to allow the script to respond to the challenge with the credentials. See Browser monitors: 401 failures on challenge-response pages
06 Apr 2025 04:07 PM
Thanks @HannahM for your guidance and support as usual.
