Any suggestions on how to avoid alerts based on few specific errors for Synthetic tests?
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi Bharathi,
which alerts do you mean exactly? By default synthetic monitors only generate problems if the monitor is unavailable from all configured locations. You can turn off problem generation in the Monitor settings -> Outage handling.
Kind regards, Philipp
Hi Philipp,
a customer configured to receive problem notifications when the test fails at one location. However, they do not want to be alerted for a specific javascript failure. They would like to either filter out that object or not have the specific resource generate an alert.
