Browser synthetic for sites using SSO smsession
jordan_rose
Contributor
Is there a way to make this work? I can get sites using ntlm to work by adding the basic authentication but not sites using sso/smsession...
3 REPLIES 3
ChadTurner
What cluster version are you on? With the release of the Credential vault I was under the impression that SSO synthetics would then work.
-Chad
Dynatrace version - 1.194.72.20200604-122905. I'm not the expert but I believe smsession involves a cookie being passed that somehow makes sso work. Most of our sites use this method and using credential vault doesn't work.
Greg_Sanders
Visitor
@Chad T. - Is there any movement on this effort?
