Synthetic Monitoring
Dynatrace managed and synthetic monitoring
Hello everyone,
Question about synthetic monitors. Is there a way to generate global outage notification based on type of http return codes or some other conditions?
I want to the global outage alert to be generated only in case if there is a timeout on browser monitor request, but if it is 403 return code, then such outage alert should not be generated.
Is it possible to do?
AntonioSousa
I believe you are referring to HTTP Monitors.
Have not done such a specific case, but would try something like
400-402,>=404
I have always used the standard configuration, which is below.
Antonio Sousa
