How to set windows maintenance for synthetic monitor
H_THIM
Visitor
Hello .
i want to set  maintenance windows of synthetic monitor (HTTP or ClickPath ) .
i have some monitor which i don't want them running on weekend ,and some other i don't want them running between 18H:00 - 23H:00 (only running during office hours) .
meaning that  during this time slot like week end and between 18H-23:00 : those synthetic monitor need to be deseabled or if cannot be deseabled i want avoid  any outage handeling .
i was thinking about to set maintenance windows for that .
could you please advise how to do that .
BR
3 REPLIES 3
AntonPineiro
If you are in Grail, I would say Synthetic for Workflows  because you have more flexible schedules.
If not, you can check use maintenance windows + Disable synthetic monitor execution. But it is flexible and maybe you need to create more than one for having all schedules.
Best regards
AntonPineiro
If you are in Grail, I would say Synthetic for Workflows. It has more flexible schedules.
If not, I would say combination of maintenance windows + Disable synthetic monitor execution . But I think you need to create more than one to have those schedules.
Best regards
Kenny_Gillette
DynaMight Leader
DynaMight Leader
Easiest - let the synthetics run all the time and create a maintenance window for when you don't want to alert/create problems
