09 Mar 2021 01:06 PM
We want to know if it's possible to create a Synthetic monitor (HTTP monitor or Clickpath browser) with a specific downtime period to not execute that monitor on a specific timeframe (after midnight, on weekends, etc).
Thanks!
Dani
09 Mar 2021 01:53 PM
I think, setting up maintenance window along with Disable synthetic monitor execution will work here.
AK
10 Mar 2021 02:02 PM
I had missed that this is possible now, very good to know! That was requested in many projects I've done.
09 Mar 2021 02:47 PM
@AK is correct @dbusquets. You can set a maintenance window that will suppress the synthetic runs. This will completely prevent that Dynatrace Synthetics from running thus cutting down your usage.
09 Mar 2021 03:39 PM
Thank you all for your help and rapid response! 🔝
21 Jul 2021 05:09 PM
Besides using a maintenance window, I'm using tags where scripts are activated/deactivated via API calls (any combination of tags can be applied). For me this works best until a true scheduler is available for Synthetics.
e.g. Tag values and meaning
D05.00_20.00 ==> Daily 5AM - 8PM
D07.00_22.00 ==> Daily 7AM - 10PM
D07.00_24.00 ==> Daily 7AM - MidNight
D09.00_18.00 ==> Daily 9AM - 6PM
WD03.00_23.30 ==> Mon-Fri 3AM - 11:30PM
WD05.00_21.30 ==> Mon-Fri 5AM - 9:30PM
WD07.00_19.00 ==> Mon-Fri 7AM - 7PM
WD07.00_21.00 ==> Mon-Fri 7AM - 9PM
WD07.00_22.00 ==> Mon-Fri 7AM - 10PM
WD07.30_19.00 ==> Mon-Fri 7.30AM - 7PM
WD08.00_17.00 ==> Mon-Fri 8AM - 5PM
WD08.00_18.00 ==> Mon-Fri 8AM - 6PM
WD08.00_20.00 ==> Mon-Fri 8AM - 8PM
WD08.00_21.00 ==> Mon-Fri 8AM - 9PM
WD08.30_19.00 ==> Mon-Fri 8.30AM - 7PM
WD09.00_20.00 ==> Mon-Fri 9AM - 8PM
WD24x5 ==> Mon-Fri
WE06.00_18.00 ==> Sat-Sun 6AM - 6PM
WE07.00_18.00 ==> Sat-Sun 7AM - 6PM
WE08.00_18.00 ==> Sat-Sun 8AM - 6PM
WE09.00_18.00 ==> Sat-Sun 9AM - 6PM
SAT3.00_17.00 ==> Sat 3AM - 5:00PM
SAT5.00_15.45 ==> Sat 5AM - 3:45PM
SAT07.00_16.00 ==> Sat 7AM - 4PM
