Can you help us understanding why it takes almost 40 minutes befor the synthetic scripts start running ?
We have a Maintenance window that ends at 6h30 but we notice that the first runs of the scripts are axecuted at 7h09.
The frequency of this script is : 15 minutes
Tx for your help.
kr,
Guy Deherder.
I dont think it should take that long, Id follow up with a support ticket just like @HannahM has recommended.
There is a misnomer about execution times however. If you have a monitor that is set to run every 1 minute, from two locations, it wont actually run every minute. For example Location 1 and Location 2 at 8:00, then again at 8:01 and so on. Rather its takes your frequency time and divides it by locations, so 1 divided by 2, gives us 0.5 or 30 Seconds. so at 8:00:00 location 1 runs, then at 8:00:30 Location 2 runs.
But as you stated yours is upwards of 30 mins after the window expires. So a support ticket would be the best solution for this oddity.
