29 Aug 2024
02:58 PM
30 Sep 2024
07:11 AM
Is it possible to monitor some TELNET call with an HTTP monitor?
Or not at all?
Thank you,
Sabine
26 Sep 2024 02:08 PM
Hi Anton,
We have the last Dynatrace version, but I don't have the option for NAM monitor creation.
I wonder if there is any missing right?
Which user group provides it?
Warm Regards,
Sabine
26 Sep 2024 04:03 PM
These are only available if you have private Synthetic location as well https://docs.dynatrace.com/docs/shortlink/network-availability-monitoring#deployment-type
Do you have a Synthetic ActiveGate?
Best regards
27 Sep 2024 08:54 AM
We have a Synthetic ActiveGate, yes.
There is an upgrade planned next week, but the version is one of the newest (same for the cluster).
For the private synthetic location ,yes, we have one.
We use too, public synthetic locations, depending the script.
But the location selection is always after the monitor type selection. Is there the issue?
Best Regards
27 Sep 2024 07:04 PM
Are you opening new Synthetic app? Where do you try to create NAM monitor?
Best regards
30 Sep 2024 08:11 AM
I don't use the Synthetic app.
We have Dynatrace Managed.
In it, synthetic monitors are created via the menu "Synthetic"
30 Sep 2024 09:27 AM
NAM monitors are available for Managed customers. You need to create them using the API. You can then see the list of NAM monitors in a new link that will appear at the the Synthetic page. It looks like the page for creating and modifying them will be available around Cluster version 302.
