21 Dec 2023
04:15 AM
21 Dec 2023
10:06 AM
i was using synthetic monitoring for a SaaS application that can only be used in a private endpoint. I had the username and password saved in the vault.
The active directory has integrated SSO for the SaaS application using SAML. I have option to manually enter the service username and password for the application but everytime I try to click on it fails.
I was thinking of trying managed identify as both the application are under Azure AD or shall i go for certificates.
01 Jul 2024 12:22 PM
Have you added the credentials to the HTTP Authentication section of the Navigate event? https://docs.dynatrace.com/docs/platform-modules/digital-experience/synthetic-monitoring/general-inf...
