02 Apr 2025
06:19 PM
03 Apr 2025
07:43 AM
if maintenance window is deleted, does it impact synthetic availability calculation?
04 Apr 2025 11:24 AM
Yes, if the Maintenance Window is deleted, then the availability will be for the whole period, including the period the maintenance window was previously covered. You can disable Synthetic monitor executions as part of a Maintenance window configuration. See documentation.
04 Apr 2025 03:41 PM
Does SLO impacted then?
07 Apr 2025 10:20 AM
If you're using a metric that excludes maintenance windows, then yes, it would. If you intend to delete maintenance windows after they expire and don't want Synthetic failures from during the maintenance windows, then I would suggest disabling Synthetic executions.
What's the use case for deleting the maintenance windows?
