synthetic transactions image is not available
kuppireddygari_
Newcomer
Synthetic transaction steps image is not available.Availability is showing 100% for all the steps.
mateusz_kulewic
Participant
Hi!
Are you running that monitor on public or private location? If the location is private, please check if your AG that is running synthetic monitors is able to reach Amazon S3 in order to upload screenshots.
Best regards,
Mateusz
Were you able to remedy this situation? We're facing the same issue and would like to know what steps to take to fix it.
