Troubleshooting
HannahM
Dynatrace Guru
Dynatrace Guru
Summary
By default, Browser Monitors are executed in a Chrome Browser that ignores certificate errors. In some scenarios, you may wish for your Browser Monitor to fail if there is a certificate error.
These steps will work for all location types - Public, Private, and Cluster.
Resolution
How to create a Browser Monitor that does not ignore certificate errors
  1. Go to Synthetic in the Dynatrace menu.
  2. Select Create a synthetic monitor in the top right > Create a browser monitor.
  3. On the Configure a browser monitor page, type in the URL you want to monitor and either use the default Name or provide your own.
  4. Select Script Mode
  5. Add the following to the configuration section under chromiumStartupFlags
                "ignore-certificate-errors": false​
  6. Add any further steps required
  7. Choose Next to continue configuration—select monitor locations and frequency. See Configure browser monitors for details.
  8. Select Next at the bottom of the page to view the monitor summary.
  9. On the Summary page, you can review and change your configuration (Change URL or name; Change configuration).
  10. At the bottom of the page, select Create browser monitor.
Update a Browser Monitor to not ignore certificate errors
  2. Select the browser monitor you want to configure.
  3. Select Edit from the quick links to go to monitor settings. Alternatively, you can go to the Synthetic monitors page, select the checkbox next to the monitor you want to edit, and select Edit at the bottom of the page.
  4. Select Recorded Clickpath , if it's a Browser Clickpath monitor, or Monitor Script
  5. Select Script Mode
  6. Add the following to the configuration section under chromiumStartupFlags
  7.  Select Save Changes
What's Next
Get advanced warning of a certificate expiring
If you would like to be warned in advance of the certificate's expiry, you can use the HTTP Monitor SSL Certificate expiry option.
https://www.dynatrace.com/support/help/platform-modules/digital-experience/synthetic-monitoring/http...
Further troubleshooting
If you still need assistance, open a chat or support ticket and provide a link to the affected monitor and explain what your are trying to do and what you have already tried.
You can find further troubleshooting tips for Synthetic in the Synthetic Troubleshooting Map
Version history
Last update:
‎16 Jun 2025 03:44 PM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thank you for Sharing this @HannahM
AntonioSousa
@HannahM,
I confess I'm a little bit confused here, and not what I was expecting: by default, a Chrome Browser does not ignore cert errors, but indeed tries that the user not proceed to a site with an invalid cert.
This implies that sites with a self-signed, invalid CA or whatever invalid cert may be out there, do not give an error by default in browser monitors?
HannahM
Dynatrace Guru
Dynatrace Guru
For Browser monitors, we start the Browser with the
--ignore-certificate-errors
parameter. This does indeed ignore certificate errors.
AntonioSousa
@HannahM,
Thanks for the clarification. If asked before, I would certainly not have said it worked this way 😁 But I do understand why it's done this way...
lsantos
Observer
Hello everyone,
I'm in need for such feature (i.e. I want the synthetic to fail if there are any certificate issues).
I've added the suggested flag but the synthetic is still not failing even tough there are certificate issues...
Anyone had success with this setup?
Thanks 🙂
HannahM
Dynatrace Guru
Dynatrace Guru
@lsantos, thanks for letting us know. Did you resolve this issue? Changing the flag works for me. If this behavior is still seen for your monitor, can you create a support ticket for us to investigate? Thanks
