yngwie_lucero
Dynatrace Advisor
Dynatrace Advisor
The plugin only needs one repository (the "repository" block from the "buildscript"), but it automatically adds the agent as dependency. You (or the customer) has to ensure that Gradle can resolve the agent dependency by providing the correct repository. The following screenshot shows which repository block is used by Gradle for the plugin and agent:
Version history
Last update:
‎03 Jan 2023 02:43 AM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thanks for this clarification @yngwie_lucero
