Troubleshooting
dominikus_randy
Dynatrace Guide
Dynatrace Guide
If I go to JBoss process dashboard -> Further Details -> Web Request -> the dashboard is empty.
Root Cause:
By the default, the JBoss EAP has no statistics enabled.
Solution:
The WebRequest Metric can be enabled by the WebGui or Config.
WebGui:
Config:
Example:
<subsystem xmlns="urn:jboss:domain:undertow:7.0" default-server="default-server" default-virtual-host="default-host" default-servlet-container="default" default-security-domain="other" statistics-enabled="true">
Version history
Last update:
‎03 Jan 2023 02:41 AM
Updated by:
Comments
ChadTurner
Legend
Thanks @dominikus_randy for this trick
Community freeze: read-only from October 22, 6:00 AM UTC, while we move to Discourse. Outage (~1h) on October 26 at 9:00 AM UTC. Learn more.
