30 Oct 2024 06:24 AM - last edited on 09 Dec 2024 08:15 AM by MaciejNeumann
Can you please help me to check whether the below alerts can be configured in Dynatrace to achieve predictive monitoring. If yes, can you please let us know the related documents or steps we can follow to configure these alerts.
Server Response Time (Response from Web Service, Routine, Function, …) |
To Setup the Server Response Time alert with below threshold: |
API Response Time |
To setup API Response Time alert with hourly, daily transactions above threshold. |
Note: We are using Managed version of Dynatrace.
Thank you for your help,
- Nowshad
07 Dec 2024 03:55 PM
Hi @Nowshad
As long as the current situation is Dynatrace managed, you have an option to proceed with below options:
Useful sessions:
You can also proceed with metric event option
Hoping it helps.
KR,
Peter
07 Dec 2024 03:56 PM
Hi @Nowshad
Feel free to review the below resource for more insights and guidance, i believe it would be applicable solution for raised case:
KR,
Peter
