Data explorer upgrade (aka Custom chart deprecation)
zietho
Dynatrace Champion
Dynatrace Champion
Dear all,
  • What: We have set a date to remove Custom charts from Dynatrace. If you use Custom charts, it's time to plan for upgrading your charts and dashboards to the Data explorer.
  • When: Dynatrace version 1.265, which is planned for release in Q2 2023, will be the last Dynatrace release to support Custom charts.
  • How: You can upgrade tile by tile, dashboard by dashboard, or all dashboards at once using the Dynatrace API (all available with Dynatrace version 1.251)
Find more details in the related documentation and blog
Let's use this thread to expose and discuss what you believe is still missing and what we can do to smoothly and successfully transition you from Custom charts to the Data explorer.
3...2...1.. shoot, we're listening!
Or, in any case...
11 REPLIES 11
AntonioSousa
@zietho,
Some I can remember rapidly:
  • Exporting to SVGs or other image, is a MUST for some of our customers.
  • Conversions are still not working OK when there are for instance some type of filters.
  • An easy way to discover in an environment which dashboards still have Custom Charts.
BTW, you have a link to an internal server, that you might want to correct.
Antonio Sousa
Thanks for sharing,
I was thinking exactly to the 3rd point.
I don't have time to explore all customer's Dashboards and verify which one is using Custom Charts.
For a specially this purpose, Is it possible to make a Dashboard in the Dashboards menu with different colors or with a specific text to know that its always using CM.
Sharing Knowledge
zietho
Dynatrace Champion
Dynatrace Champion
Dear both,
our approach (answer to this) should go out with 1.252, where we provide you with an additional filter in the dashboard list. When set, you will only see dashboards with Custom chart tiles on it.
Bonus: when you upgrade a or multiple dashboards via the API (release with 1.250) it will skip dashboards without Custom chart tiles on them. So upgrading all is as simple as sending in all. We hope both in combination provide you with sufficient means to quickly and successfully upgrade all your dashboards.
regards Thomas
DanielS
DynaMight Champion
DynaMight Champion
Please, have in mind that some end users are going to upgrade their dashboards and they lack knowledge of using API. Please do it as painless as possible. Thanks.
The true delight is in the finding out rather than in the knowing.
zietho
Dynatrace Champion
Dynatrace Champion
Spoiler: there will be a button in the UI (1.251) both on the list and the dashboard like:
DanielS
DynaMight Champion
DynaMight Champion
Great, maybe I can ask my mom to update Dashboards. 😁
I could get kids to do 🙂
zietho
Dynatrace Champion
Dynatrace Champion
Yes, the migration capabilities lagged behind the features we added.
The last additions (axis settings, relationship filters, units) were added until sprint 1.251.
Starting with this sprint the upgrade should beable to deal with all your previous settings.
If you find something with or after 1.251 please report it via a support ticket!
regards
Thomas
ct_27
DynaMight Mentor
DynaMight Mentor
We still use Logging v1.   Logging v1 still has a link that directs the user to Custom  Chart. Could someone please fix this link to not go to Custom Chart.  I've already opened a support case '#50316' for which DT said they would fix it but have no ETA on it.  Unfortunately they have already closed my support case without a full resolution.
I'd suggest this be fixed before 1.265.
HigherEd
zietho
Dynatrace Champion
Dynatrace Champion
Thank you for making me aware! Will raise this internally with my fellow colleagues from logs then!
Has anyone used the API to update all of their dashboards. Is there really any benefit of doing 1 by 1? We have a ton of dashboards that need updating and the API caught my eye. Anyone have issues with that? Issues as in either the update did not work or the update worked but maybe the metric expression behind the tile is a little off? I have no plans to update 1 by 1 if I can help it.
