Export incoming and outgoing connection data to a host through API
amareshanand
Observer
Can you please advise, if there is any way to export incoming and outgoing connection data to a host through API.
Thanks & Regards,
Amaresh Anand
ChadTurner
DynaMight Legend
DynaMight Legend
This can be done via API with Environment V1 (Even though it says its deprecated)
but also via the environment API V2
-Chad
Hi @amareshanand
Check the fromRelationships and toRelationships within the Response body objects of Monitored entities API - GET entities list for entity type HOST
HTH
Yos
