Cassandra backup problem
Gabriella
Visitor
Good morning Team.
We have the following message Make backup script has failed Cassandra - failed to create new snapshots on host.
Could you tell me in which path I can review the logs to check why it is failing?
Hi Gabriella,
The log is usually in /opt/dynatrace-managed/cassandra/log/cassandra.log
Elena.
Peter_Youssef
Champion
Hi @Gabriella.
Also find the below created directories after successful cluster setup for future consideration:
  1. Dynatrace installation Binaries: /opt/dynatrace-managed
  2. Dynatrace default installation directory: /var/opt/dynatrace-managed
  3. Session replay store: /var/opt/dynatrace-managed/server/replayData
  4. Metrics repository directory: /var/opt/dynatrace-managed/cassandra
  5. Elasticsearch store directory: /var/opt/dynatrace-managed/elasticsearch
  6. Dynatrace raw transaction store directory: /var/opt/dynatrace-managed/server/
Kindly note:
  • These are the default installation directories, unless otherwise specified by Infrastructure team during the cluster setup.
KR,
Peter.
