02 Dec 2019
		02:32 AM
		13 Apr 2023
		10:46 AM
		 Karolina_Linda
			Karolina_Linda
Hi all,
I'm looking for use cases of Dynatrace for PCIDSS-compliant systems.
Are you using Dynatrace for PCIDSS-compliant systems?
How are you using it?
Takahiko
14 Jan 2020 10:06 AM
Second option is ability to extract sensitive data using request Attributes. Here you can add permissions only for users that has proper contracts signed. Only they for example will be able to create such configurations and read values. For others this option may be masked.
